When a Layer 2 Virtual Service Network (VSN) extends outside of the Distributed Virtual Routing (DvR) domain, DvR Controllers can route traffic that enters on the network-to-network interface (NNI) by using Virtual Router Redundancy Protocol (VRRP).
The VLAN must be a DvR VLAN. A DvR VLAN is a VLAN configured on a DvR Controller with a VLAN IP address, a VLAN I-SID, the DvR gateway IP address, and DvR enabled.
If you enable this functionality, the switch automatically creates a VRRPv2 interface with the virtual router ID (VRID) 37 and a holddown-timer configuration of 60 on the DvR VLAN that you identify for VRRP election. You can configure one VLAN for election.
  1. In the navigation pane, expand Configuration > VLAN.
  2. Select VLANs.
  3. Select the Advanced tab.
  4. For DvrVrrpElection, select true to select the election VLAN for DvR VRRP.
  5. Select Apply.
  6. In the navigation pane, expand Configuration > Fabric.
  7. Select DVR.
  8. Select the Globals tab.
  9. Optional: For VrrpPriority, configure the DvR VRRP priority for the elected VLAN.
  10. Select VrrpEnable to enable VRRP on all DvR Service Instance Identifiers (I-SIDs).
  11. Select Apply.
Use the data in the following table to use the Globals tab.
Field
Descriptions
DomainId
Identifies the domain that the node belongs to.
The range for a Controller or a Leaf is 1 to 255. Set to 0 if is not configured.
Role
Specifies the role of the node in the domain as one of the following:
  • controller
  • leaf
  • isolatedController
Enable
Specifies whether Distributed Virtual Routing (DvR) is enabled on the node.
Configuring a Controller or Leaf sets this parameter to true.
DomainIsid
Uniquely identifies the domain I-SID that the node belongs to.
0 indicates that is not configured.
BackboneIsid
Uniquely identifies the backbone I-SID that the node belongs to.
The valid backbone I-SID is 16678216; it is configured to 0 if is not configured.
GatewayMac
Specifies the Gateway MAC address used by all domains.
InbandMgmtIp
Specifies the In-band Management IP address configured under IS-IS.
You can use this IP address to manage the node, irrespective of whether DvR is enabled on it.
InjectDefaultRouteDisable
Specifies whether injection of default routes is disabled on the Controller in the domain.
By default, Controllers inject default routes into the domain so that all Leaf nodes in the domain learn these routes with the next hop as the Controller that advertised it. Select this parameter to disable this behavior.
VirtualIstLocalAddr
Specifies the local IP address of vIST, if vIST is configured on a Leaf.
You cannot configure vIST cannot on a Controller.
VirtualIstLocalMask
Specifies the local subnet mask of vIST, if vIST is configured on a Leaf.
You cannot configure vIST on a Controller.
VirtualIstPeerAddr
Specifies the peer IP address of vIST, if vIST is configured on a Leaf.
VirtualIstClusterId
Specifies the cluster ID of vIST, if vIST is configured on a Leaf.
Set to 0 if vIST is not configured.
VirtuaIIstIsid
Specifies the I-SID if vIST is configured.
OperState
Specifies the operational state of the node.
VrrpEnable
Enables Virtual Router Redundancy Protocol (VRRP) advertisements on DvR VLAN Service Instance Identifiers (I-SIDs). The default value is disabled.
VrrpPriority
Configures the VRRP priority for the elected VLAN and associated I-SID. Switches advertise their priority to use in the primary router election process. When multiple Controllers elect the same DvR VLAN and I-SID, the Controller with the higher priority becomes the primary router. The elected Controller sends VRRP advertisements on all DvR VLANs.
The default value is 100.
VrrpElectionVlanId
Displays the election VLAN for VRRP on DvR I-SIDs. A value of 4095 indicates no elected VLAN exists.
